aircompressor problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2009, 10:01 PM
I was given a speedaire 60 gall 5 hp 2 stg setup in good cond. I had to mount the comp and motor to tank and pipe it as some pcs were missing. Started and ran fine to 50 psi and then exceeded my motor FLA. Problem increased longer it ran. Does it look like a cyl might be seizing or could this be a sheive problem. Help?
Old 11-21-2009, 11:32 AM
This sounds a little simple, but is they're a check valve between the tank and the compressor? If not you have to have one and its a cheap fix. Tim
