aircraft remover - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2004, 12:58 PM
406 six speed
aircraft remover
after stripping a car with aircraft remove...what is the best way to clean it off.
Old 03-15-2004, 01:00 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I wipe it down with blue paper towels and lacquer thinner with good results.
Old 03-16-2004, 08:12 PM
mickey64's Avatar
If its the same stuff I use almost everyday at work, it actually cleans up with water, but thats not to enviermentally correct ,lolll. actually we use Methyl-ethel-keytone, it evaporates very quikly,, I don't know of a better product, but I don't know if its available to the general public , I'v herd its hard to get in the states
Old 03-16-2004, 10:54 PM
low77ride's Avatar
Yea i use water bacuase it brakes down the acid and makes it neutral the just wait till its dry then use solvent.
" You cant piss on what you cant catch"
Old 03-17-2004, 08:44 AM
Wiki Edits: 21
That stuff is caustic, not acidic.
