Airtex fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2010, 09:03 PM
Airtex fuel pump
I have several early Ford cars and vehicles (B's, V8-60's, 21 and 24 stud flat heads) so I hope this allows me to ask a question about an electric fuel pump that I have installed on a dune buggy with a 914 Porsche engine.
The pump never stops running (pulsating) while it's getting current from the switch.
I have mounted the pump in a horizonal posiition about 18 inches below the tank with a pressure regulator on the outlet side. (A Filto-Reg which is set at 5.5 psi).
The engine runs, and I have fuel coming to the carb (although it doesn't feel like 5 psi).
I have good flow from the tank to the pump. I removed the fuel regulator and plugged the pump outlet, turned the switch on and the pump never stops pulsating.
I can't believe that this pump should operate continually.
Thanks for your help
Don
Old 10-14-2010, 10:30 AM
I just installed an E8012S and there is no provision for a shutoff. It simply peaks at max pressure, but keeps on running. This is normal.
GM uses oil pressure as a source to shut it off in a crash. Ford uses an intertia switch. The only reason any manufacture shuts their pumps off is to prevent fuel flow in a crash (once the engine dies).
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 04:27 PM
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 07:18 PM
No fuel to carb, do have fuel at pump inlet - replace? bruceg Engine 8 04-22-2010 08:41 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
