(airworld2) Cheap wiring for 700R? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2004, 09:15 AM
How can I wire up my 700R (1986) to lock up in 4th gear with parts from a wrecking yard or around the house keeping the cost to a minimal? I recently installed the tranny and its running great, but understand that I need the lock up function to keep it from overheating? Thanks in advance..................
Old 05-24-2004, 09:05 PM
airworld2's Avatar
700 wire for lockup
run 12 volt hot wire from fuse box to front outside case connector
drop pan install normal open pressure switch to forth gear oil port
in valve body location next to 1-2 accumulator cap(passenger's side of valve body) connect a wire from pressure switch to ground wire of the lock up solenoid this switch will close shortly after 4 gear shift about 1 to 3 mph after 4th gear shift which will ground thew case and lock up should occur, this is only 1 way that you can fix lock up cheaply and relay on it to work
airworld2
