Al Payne - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2006, 03:27 PM
Al Payne's Avatar
Al Payne
I need help in mounting a 351 EFI Windsor Motor. The original mounts are stripped out in the front holes, and one is cracked out. the motor has only 27000 miles and is in good condition. I remember a trans-adapt plate the mounted across the front of the motor, leaving the back mount holes usable. Is there anything anywhere. I have a 1930 coup with 4-bar sup and cross steering. Also 4" drop superbell.
I also need to know how to set the angle of the motor to match the rear. 4 deg. off horz. Any help would be deeply appreciated.
I hope that this makes some type of sense.
Please call Al @ 303-757-9471 8am to 3pm, leave # and I'll call you back.
Old 05-30-2006, 04:37 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Here is a discussion or drive line angle which can be helpful to you.. Pinion Angles and Driveline Setup for the Street
There are some others..do a search and they are in memeory somewhere..
H'mmm motor mounts..that fails me at the moment I will do some searching...
Pm me if you wish
Sam
Old 05-30-2006, 05:01 PM
Wiki Edits: 3
Did some checking and Speedway has some mouts the might work...that trans adapt plate may be esy to duplicate..take a pice of door skin (thin plywood) and make a template..there may be a local steel shop that can laser cut one for you if you have a pattern..
Hope you get it fixed..
Sam
installing a 6 al ignition prostreethotrods Electrical 1 04-02-2006 08:19 PM
Big Als Toybox/ Al Lomabardo Enterprises Howie Poulter Engine 1 09-18-2005 09:31 PM
My name is Al & I'm a rodoholic CAHotRodBoy Introduce Yourself 1 01-16-2005 02:01 PM
edelbrock AL timing cover 68chevelle_ss Engine 1 03-29-2004 11:15 PM
My engine is eating AL! mcbroom Engine 10 12-01-2003 08:29 PM
