Alan Grove Alternator Mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2014, 10:31 PM
Anyone here use the Alan Grove 200 R alternator bracket (SBC, short pump, passenger side) with the Edelbrock Performer intake manifold?
I am trying to determine if the heater hose connection coming out of the intake will interfere with the alternator before I invest in the bracket.
Thanks
Old 03-18-2014, 10:51 PM
327NUT's Avatar
I really can't help you on the Grove parts but I used "Bill's Hot Rod Co." on my 331" sbc. I think it's much nicer, not as bulky looking and is tig welded. For just the alter. you would use #150 which is $64 plain steel to $99 for chrome. See .... billshotrodcompany.com
Old 03-19-2014, 09:17 AM
RWENUTS's Avatar
Bills Hot Rod Company
Old 03-19-2014, 11:55 AM
You could use a Header Power Bracket. Here is also a picture that shows how the heater lines would route with the Performer RPM manifold, with the extended bracket, so you can determine if they can get around the alternator. Looks like the water pump hose is fine and the manifold hose could be shortened for a bit more sweep to the back behind the alternator.
HEADER POWER BRACKET¬*¬*¬*¬*¬*¬* - Home
Old 03-19-2014, 09:10 PM
Thanks but I am having trouble finding a passenger side alternator bracket for the short pump. The Bills Hot Rod 150 series is the correct side but long pump only. Bills also has several series that will work with the short pump but they all have the alternator on the drivers side.
I have a compressor mounting bracket for the passenger side similar to the Grove 200R but the bracket locates the alternator to far back.
I tried a Speedway Motors bracket and the alternator ran into the heater hose fitting and also had virtually no adjustment as the adjustment bolt was at the end of the slot when the alternator was rotated to clear the intake.
I chose to go with the short pump to provide better radiator clearance but I am beginning to think it was a poor choice.
Old 03-19-2014, 09:49 PM
Not a mistake. The Header Power Brackets only work with the short and Corvette water pumps and will put the alternator where it needs to be.
Old 03-19-2014, 11:00 PM
Scooting's Avatar
Hi, I did the Alan Grove Brackets with the opposite setup than you. My Alternator setup is on the drivers side and compressor on the passenger side. Due to the three water outlets in the Preformer manifold, I did not have any problem hooking up water or gauges. Looking carefully at the pictures in Alan's catalog, the clearance in the water passage appear to be similar with both setups. I would not expect any problem and would go for it. The problems I did have installing the brackets is I had to engolate the bracket holes fitting around the intake mounts, including the spacing for the fuel ports. You also have to be careful with the amount of spacers on the water pump area to get perfect alignment - had to modify the shims and add washers. Not a big deal but did not expect it from a purpose made piece. I changed manifolds to Preformer RPM Air Gap and was able to use the same mounts - water hookup now hooks to rear passage by Dist. Good Luck, Ray
Old 03-20-2014, 06:11 PM
Thanks Scooting, I agree that the pictures in the on-line catalog look like it should clear but I am a little gun shy as I have bought two brackets already that didn't work. Maybe the third time is the charm.
Toddalin - I don't have headers but the rams horn Corvette manifolds. It appears that the Header Power Brackets provide a mounting location similar to the one cast into the iron manifolds. However, I don't know what bolts to either the Header Power Bracket or the cast iron manifold to actually provide the alternator mounting feature, and where the adjusting arm mounts. Do you have any additional information of the additional parts required?
Old 03-21-2014, 12:36 PM
The extended Header Power Brackets will work with the rams horn manifolds because the bolt holes are in the same locations. You would need two bolts that are 3/4" longer than the originals, and two 1/2" spacers. This will place the bracket along the outter edge of the exhaust manifold, but it just looks a bit weird.
You also need an F-Bracket that actually mounts the alternator to the Header Power Bracket (or its billet spacer). Get one that "cinches" the alternator forward as you tighen the pivot bolt.
And, you need a J-bar. The F-Bracket and J-bar were standard issue back when the alternator mounted to the exhaust manifold and most people already have these pieces either from stock, or from moving up from the cheap, stamped, aftermarket header mounts. If not, they can be obtained from any of the major suppliers fairly cheap. The original F-brackets are better made (thicker) than the cheaper available replacements shown in the picture (~$8 on ebay), but cost more.
BTW, the J-bar mounts to the back, and not the front of the alternator.
Old 03-21-2014, 02:07 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Thanks
I used the 200R on my '31 Tudor, with a Edelbrock Performer RPM Intake Manifold, Cat. #7101.
Old 03-21-2014, 03:04 PM
Sorry for the double post.... post timed me out before I could get some photos...
I am not running a heater, so I have the ports plugged. Nonetheless here are some photos for ya that might help.
Name:	200R Bracket and Heater Hose.jpg
ID:	129890   Click image for larger version
Name:	200R Brackey and Heater Hose.jpg
Old 03-22-2014, 12:56 PM
Thanks LakeRoadster, those pictures help a lot.
Alan Grove Brackets jturbo7 Engine 5 12-29-2010 04:53 PM
low mount alternator on a g body bracketeer Electrical 0 11-11-2007 05:40 PM
Alan grove brakets malibu68 Engine 2 04-09-2006 11:38 PM
Aluminum Alternator mount... ground? blndweasel Electrical 5 03-16-2005 09:36 AM
Alan Grove Brackets and Belts syborg3D Engine 1 08-21-2004 10:11 PM
