aldan coilovers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2007, 05:23 PM
aldan coilovers
Hi
I bought a hotrod that has aldan eagle coilovers on the rear.I know nothing about them,how do u tell if they need rebuilt,and can u buy kits or do u have to send them somewhere? What is the thumbscrew at the top of the shock do? I noticed that some Time in the past the sway bar was rubbing in the driveshaft,when sitting still there is about 4" between them,I don't know when or where they were hitting ,It might have been before the aldan's were put on thats why I would like to know a little more about these coilovers.I see i can adjust ride hight with the big nuts on the bottom.but I don't want any more fender gap than I have now.I sent a message very similar to this one to Aldan,but never heard back.
Thanks
Gary
Old 02-14-2007, 07:41 AM
I believe Pete & Jake's was the importer of the Aldan shock line, and may still be. Give them a holler.
Old 02-14-2007, 09:29 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Depending on the Model that you have, that knob will control the Compression, Rebound or both Comperssion/Rebound adjustments.
From thier website:
SHOCK ADJUSTMENT The Aldan Eagle adjustable shock has six valve damping positions, so you may dial in the ride you like. To increase firmness, rotate the adjusting knob (located at the top of the shock absorber) clockwise. When the knob is rotated all the way out (counterclockwise), the shock damping is at its softest setting
Old 02-14-2007, 09:45 AM
Thanks guys,I'm learning as I go thanks to a lot of guys on this site
Gary
Coilovers, how do you adjust them? jgrant Suspension - Brakes - Steering 8 10-30-2005 07:44 PM
Aldan or QA-1? (sorry about the misplaced post) Elevinpointsixtoone Suspension - Brakes - Steering 3 03-02-2005 06:46 AM
Chrome Coilovers 33chevy-guy Suspension - Brakes - Steering 3 07-25-2004 08:30 PM
Coilovers and mounting GLN305 Suspension - Brakes - Steering 8 09-29-2003 09:02 PM
Aldan coliovers - adjustment query Limey Simon Suspension - Brakes - Steering 3 05-08-2003 10:15 PM
