aligh hood with fenders - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2012, 10:14 AM
nasty68's Avatar
hello , I am trying to align my hood on my 68 chevelle and can seem to get it stright with fenders, is there a right and easy way to accomplish this. Help
Old 02-29-2012, 10:26 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
What seems to be te problem and some pictures would be helpfull.
Old 02-29-2012, 10:30 AM
nasty68's Avatar
I had to change the springs and now the hood won't close stright. Hits or trys to hit on one side and back is high. I think I got that fixed but the side to side agustment is dificult to obtain. when the hood is almost closed .it wants to hit on side toward the front
Old 02-29-2012, 11:25 AM
My understanding, and it could be wrong, is that you align the hood to the cowl. You also align the doors to the body, and then you align the fenders to the door, and the hood.
Old 02-29-2012, 12:27 PM
nasty68's Avatar
all tha tis correct but getting hte hood to align to fenders is a big problem if you haven't done it before
Old 02-29-2012, 12:41 PM
gto_ron's Avatar
hood side to side alignment
I just read an article in our monthly GTOAA magazine on hood hinges. Worn hood hinges make hood alignment next to impossible. After reading I realized that was my problem and intend to have my hinges rebuilt. If this applies to you I can send contact info on the company that specializes in rebuilding hood hinges to factory appearance and performance.
regards
Ron
Old 02-29-2012, 12:45 PM
swvalcon's Avatar
On the 68 chevelle the back of the hood meets the windsheild so that you dont worry about all you need is to aline the front edge and the sides. Some times if I 'am having issues with a hood I will remove the striker so hood wont latch then loosen the hood just enough that with a little pressure it can be moved.Now close the hood and with a paint stick or plastic tool move the hood around until your happy with the gaps. You want the sides to be even and both edges of the gap at the front to be the same. The trick is getting the hood open to tighten it back up without it moving. These cars never did have perfect gaps so all you can get is as good as possible.
Old 02-29-2012, 12:52 PM
nasty68's Avatar
side to side hood align .
Hey, thanks for the info . sounds like a thing to try . thanks again for the info . My email address is caleyes68@yahoo.com. I have another problem with electric with a turn signal on 46 ford that you might help me with. send me your email address so i dn't have to go her all the time and reread the quotes if you don't mind . I really don't mnd but in the middle of putting a computer together. too many projects at one time I guess
Old 03-03-2012, 06:16 AM
deadbodyman's Avatar
Wiki Edits: 11
You have to take the latch out first ,adjust the hood then replace the latch.right now the hood is following the latch ,so no matter how much you adjust the hood,it'll always end up in the same spot
Replacing a metal hood with a fiberglass hood dasyhard Body - Exterior 9 07-12-2011 11:18 PM
Hood pins verse stock hood latch 62440 Body - Exterior 3 08-23-2010 10:30 AM
Poll: Showing cars - Hood up or hood down? loyter Hotrodders' Lounge 23 06-24-2007 07:21 AM
fiberglass fenders & hood - who has them, what brand, how much finish work? Chuck78 Body - Exterior 10 09-12-2006 04:36 PM
Hauling some fenders and hood a long way? skeeveman Body - Exterior 3 01-01-2006 11:50 PM
