Under the timing cover should be a "010"=1%nickle.If it says "010" and "020" it means 1% tin and 2% nickle.This is according to The Chevy Interchange Manual.My 2-bolt main block is 010 and 020, so apparently it aint just 4-bolts that are stronger.Good Luck.
High nickle and high tin blocks are "supposed" to be better than the other blocks, but it's been debated on here many times by the machine shop and builder guys.
Overall, if the block (any block actually) is sound, as in free from defects and passes a sonic wall thickness test, it's a good block. Now, if you are wanting to get a million HP out of a stock block, then no, it's not a good candidate for that, but for a good street builder, they are fine. Mark |
On some other forum (to which I have a link on some other computer) has a GM foundry worker who explains the whole kit and caboodle. First of all, the casting number that ends with 010 has nothing to do with the nickel content. It simply denotes the casting number. On the side, there are "010" and "020" castings that are rumored to denote the nickel and tin content; the numbers standing for 1% and 2%. The nickel makes it harder, and the tin helps it flow into the mold better.
In truth, even if it has the 010 on the side, its not necessarily a high nickel block... and even if it were, that doesn't make it good for high performance. Harder means more brittle. Over the years, GM has made a lot of engines, and the ones that get the higher nickel content have been the low-rpm engines: caddy 472/500, 366T, 350 in truck applications, Olds 455. Vibrations are what can really kill high-rpm blocks, and the harder the alloy, the less they are able to absorb them. Think of it like a wooden table vs a glass table. Whack the soft wood with a hammer and it dents. The glass is obviously harder, but what happens when you whack it with a hammer... The same is true of cast engine parts vs forged. Forged parts absorb impact which is what makes them suited for high performance. Cast parts are more brittle. I actually avoid high nickel blocks for high RPMs. I seek them out for street reliability and low-rpms GM used the 010 casting with a wide variety of alloys depending on the application. Its a reliably good casting with a little thicker main webbing, and reliably thick cylinder walls and decks. But don't count on it to have any specific nickel content.... nor should nickel content be confused with high performance. Harder does not equal stronger. |
We always look at the camshaft area from the front of the block, and the area around the freeze plugs to see if they are drilled in the center of the casting,or off one direction or another, it's an 'ol timer way to visually see if the block has "core shift" then have it sonic checked if you plan on a .060+ overbore!
Presicely!
Again... high nickel blocks are HARDER. That does NOT imply stronger. Cast cranks are HARDER than forged cranks. Do you rush out and buy a cast crank for high performance builds? You have mistaken "harder" with "stronger." That is just not the case. Cylinder wear is not the only factor. If I want to build a long-lasting, low-rpm motor, I'll build a Caddy 500. They have the highest nickel content of any GM engine... but they also have been known to snap off mains at high RPMs. |
| HP limit for 400 Chevy 4-bolt main?? | hotrodf1 | Engine | 23 | 04-22-2008 07:39 AM |
| Mail order dry good supplies? | SLR_65 | Body - Exterior | 1 | 09-29-2007 01:43 PM |
| Karma, good omen or whatever......... | Hippie | Hotrodders' Lounge | 3 | 03-14-2007 07:10 PM |
| Changing sanding blocks, when changing grits, is this good or bad? | Ripped | Body - Exterior | 2 | 02-06-2007 03:47 PM |
| HF tools, good or bad | oldred | Garage - Tools | 17 | 11-19-2006 03:05 PM |
