All I see is copper...
400 sbc. previously lined bored, bored .020 over ,crank cut .010, thrust rebuilt. tore down tonight and all bearings show copper on at least one side( some both). on rods all bearings show copper on on piston side of rod, with small grooving on cap side, but no copper. and on mains, copper is on main cap side of crank. what the hell happened? tons of oil pressure before i tore it down. originally thought i had burned a ring(moly rings) and im pretty sure i did. will try to get pics up tomorro, but what does this usually occur. only bearings with no copper on either side was #5 maincap.i built the engine so any questions can be answered.
Please provide:
Squish measurement Combustion chamber volume Head gasket thickness Deck height Piston crown arrangement (dish, flat, dome) Intake closing point on camshaft Was cam installed straight up |
Did you plasti-guage for tolerance before buttoning it up.
I have seen good machine shops make critical errors in turning a crank down. If the leave to much material you will not have enough room and metal will rub. We always check tolerances at torque specs. It sucks to take it back apart to check it, but then you are certain it is right. |
| copper exhaust gaskets......HELP!!!! | trick66 | Engine | 11 | 12-10-2006 10:12 AM |
| Copper Pipe | Kenny G | Garage - Tools | 11 | 06-30-2006 07:51 PM |
| Banjo crush washers: copper vs alum? | Dan B | Suspension - Brakes - Steering | 7 | 01-15-2006 07:19 AM |
| More garage wiring questions | grouch | Garage - Tools | 26 | 06-11-2005 11:23 PM |
| Copper okay for trans cooler line? | cboy | Transmission - Rearend | 10 | 05-06-2005 10:16 PM |
