ALL OVER THE ROAD - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2003, 01:09 PM
Post ALL OVER THE ROAD
I HAVE A 78 TRANS AM THAT WHEN GOING DOWN THE FREEWAY I LET GO OF THE WHEEL AND IT GOES RIGHT? MY STEERING WHEEL HAS A LITTLE PLAY IN IT BEFORE THE WHEELS TURN? AND IF GOING DOWN THE FREEWAY AND VEER SIDE TO SIDE THE REAR FEELS LIKE IT HAS LOW TIRES ?PRESSURE IS 40 PSI ALL 4 CORNERS.HOW CAN I FIX ALL THIS IN MY GARAGE? I HAVE ALL NEW TIE RODS AND ALL THOSE LITTLE STEERING ARMS UNDER THERE ? I JACK THE FRONT UP AND TRY AND PUUL SIDE TO SIDE AND UP IN DOWN THERES NO PLAY SO I GUESS MY BALL JOINTS ARE GOOD THANKS FOR YOUR HELP
Old 02-09-2003, 02:05 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I would get it aligned to start with.
Chris
Old 02-09-2003, 02:36 PM
Don Meyer's Avatar
Post
You can NOT tell that way if the is a bad ball joint.......go directly to a shop that does front end work.
