All Plugged Up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2006, 08:09 PM
All Plugged Up
Ok Guys how do you determine plug heat range??? I have a 355 sbc, 280 comp cam, mild port fulely heads (202 int. 194 ex) - balanced, hypernutechnic (?) pistons, petronix ign. (14 initial, 32 total) and here's the killer 11 1/2 to 1 compression. What spark plug should I use??? I want to put a nitrous plate (100 hp) when I've got it dialed.
Thanks for your help
http://www.hotrodders.com/forum/newt...ewthread&f=21#
Confused
Tim in North Carolina
Old 04-14-2006, 09:28 PM
i like accel u grooves there hard too foul out i have about the same setup
Plugged Fuel Line - What to do? impcon Engine 6 01-30-2006 12:33 PM
Gas Tank Plugged Granddad's51 Engine 7 07-14-2005 12:58 AM
Plugged Cat Cruiseomatic Engine 5 09-12-2004 04:27 PM
plugged breather, overheated, what blew? Biker Engine 4 07-10-2004 06:53 PM
carb backfiring nativechoppers Engine 3 02-06-2004 05:23 AM
