OK I didnt read every comment but here is my 2 cents worth,and if someone else said this then by accident Ill repeat it.
First thing I would do is to snatch intake dizzy and heads, bring pistons(every one of them) to TDC and measure deck height, this will tell u if the eng has to pulled or not,ok so lets say you find 0 deck and a reasonable c.r. piston. Now youll know weather problem is in top end or not. If deck is at or close to 0 and you have flat tops,then get rid of that cam,n choose another when u put cam in,time cam "straight up",this is not just aligning timing marks and if u dont no ,ask. 2nd thing I would do after cam ,is, get rid of heads n use somethig close to mid 60s c.c. I think the carb is no problem for now,you may want to change this to a larger carb later,650 or so,although 50 c.f.m. are really not gonna make a lot of difference. Your timing sounds right, I take it total (mech+ initial)is about 38 or so,of course check pointer when u time cam. With 0 deck,flat tops,good cam ,ign initiated properly,and correct intake,this engine should make that vette go pretty good,headers would definetly be a big + too. accolades to bogie,very,very knowlegable eng builder. Hope this helps. |
There has been alot of good information passed along here and my question in the beginning was why did i not gain enough torque to break the tires loose and appreciate all of the responses.
I believe that has been answered and the answer is because of my cam choice,comp ratio, and choosing to keep stock heads along with the close ratio 4 speed. The car sounds old school good and runs extremely well from 3k up which is a good thing that the original L82 didnot do well before. I appreciate everyones input and suggestions and think i may just rebuild the 71 rectangular port big block 454 i have in the corner over the winter to L88 standards or better (with input from the folks here) and eventually swap engines. So for the time being it is what it is and i will just try to fine tune what i have in order to get it running as crisp as possible for what it is. I am sure it can be cleaned up a little more by way of carb tuning, initial and advance timing along with headers and exhaust. |
