Long time Lurker and now need your expertise!!
Ok here is the deal, My Corvette is a 74 L82 4 Speed car 73k original miles with the 3:72 rear end I have not been happy with the performance of the L82's Bottom End Torque so some changes were made.
Block was line bored .30 over and decked. the rotating assembly was balanced, forged flat tops, Crane Fire Ball II 290H Cam (1800-5200 rpm)-224/224 duration, 107 lobe centers,454/454 lift, Performer aluminum intake, Holley 4160-600 cfm single line, 882 stock heads professionally massaged and rebuilt with bronge guides etc, stock rockers, crane matched springs,Mallory unilite mechanical advance electronic ignition factory 20 degree mechanical advance "No Curve" timing is set at 18 btdc idling at 800 rpm, nice even compression across all cylinders, runnning 92 octane.......
Here lies the problem the car starts right up no timing drag hot or cold and runs great,no pinging, no stumbles or hesitations, temp stays about 190 drives great on the road 3500 rpm at 70 mph and runs well stop light to stop light when just driving it normal.........PROBLEM is when you try to stand on it from a stop light it doesn't have enough torque to even break the tires loose....this rebuild has about 5,000 miles on it so its broke in well and i am ready to find the right tune the car sounds awesome at idle but the torque performance didn't seem to change from what it was before the rebuild!!!
What am i missing here i just can't seem to figure it out, why have i not realized a torque increase etc...
All opinions and suggestion welcome!!
