Alloy wheels welded to steel hubs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2011, 06:02 PM
Duane lxiv's Avatar
Last journal entry: headliner bow ends
Hey guys, any tips on how remove alloy wheels that have galavanticly welded to the hubs?
Old 02-20-2011, 06:44 PM
PB blaster may get in there and loosen is some......but more likely you will have to heat it......the alloy should expand a great deal more than the steel so it may pop them apart....with the aid of a good dead blow
Old 02-20-2011, 06:50 PM
If the wheels with tires are attatched to a running car I have had good luck by looseing up the lug nuts a couple of turns and driving the car slowly a few feet and hitting the brakes hard.
Old 02-20-2011, 06:55 PM
BOBCRMAN@aol.com's Avatar
Henry.. I tried that once. Went around the residential circle at 35-40 mph bouncing off curbs and sliding sideways. Fanally after three rounds the d&mned thing came loose.. Neighbors thought I was nuts,,,
Old 02-20-2011, 07:08 PM
T-bucket23's Avatar
Wiki Edits: 26
PB Blaster from the back and around teh lug studs has always worked for me. Spray it, walk away for a half hour. Use a plastic or rubber hammer and they should come right off.
Chet
Steel Wheels ss396si Suspension - Brakes - Steering 2 04-29-2008 11:57 AM
5 Lug hubs with 6 Lug Wheels... garretthes Suspension - Brakes - Steering 1 08-08-2007 04:45 AM
steel wheels Markk General Rodding Tech 1 06-08-2006 03:57 PM
Paint for alloy wheels jjl Body - Exterior 1 12-24-2005 11:44 AM
Alloy wheels corrosion. What to do? asennad Body - Exterior 1 05-08-2003 06:45 PM
