-   -   Almost finished fitting / shaping f/g trunk, starting the hood (http://www.hotrodders.com/forum/almost-finished-fitting-shaping-f-g-trunk-starting-hood-88577.html)
Ripped 05-04-2006 11:53 PM
I have to say I did not think it was going to take 8 weeks of work (after work at night) to fit the fiberglass trunk and extensions, but finally there is a light at the end of the tunnel. Tonight I flipped the trunk upside down, and began to tune up the underside of the edges and lips where reshaping took place, I hope it does not take more than a few nights.
I am now preparing for the fiberglass hood and nose section /fascia. This is much better fitting than the trunk to begin with. I did not think it would take more than a few days. However after my pickiness with the trunk fitment, I think a few days is overly optimistic. I hope that my experince on the trunk will make me a little speedier at taking the right steps in getting the hood aligned, gapped, and shaped to the fender and fascia contours.
I guess if I figure on another 8 weeks, I won't be in a hurry ;)
I am very pleased with how the trunk looks, I'll post some pics soon.
kenseth17 05-05-2006 02:58 AM
Glad to hear you are making some progress ripped. Just think how good you will become at fiberglassing and shaping after this. I hear you on the not planning on it taking the time it does. That is why if someone asks how long something will take to do, I won't give a firm answer. You never know what hurdles you will run into and have to overcome.
baddbob 05-05-2006 05:31 AM
It sounds like you're taking your time and perfecting the fit, the final product will be well worth all the hard work. I've never seen a fiberglass part that didn't need some amount of straightening or fitting. You're going to have one nice ride when she's all done! Bob
readdirections 05-05-2006 05:50 AM
i also went thru the same problems with my fiberglass trunk lid. i also found pockets under the gel coating. had to go all over with a scratch awl and pick out the pockets, some 1 1/2 " long and sand the cavities and fill with duraglass filler. found it to be the same with my side scoops. i am leary of painting , so i may leave in epoxy primer for a while.
