We're winning the case!
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #1
Old 07-18-2005, 11:12 AM
Bluepen's Avatar
Bluepen Bluepen is offline
Just a firefighter
Bluepen's barnstar
Wiki editor
Last wiki edit: How to title a hot rod
Wiki Edits: 2
Almost messed up big time
Now for me being a firefighter and not catching this sooner is pretty bad in itself.
I've been working on my '46 Chevy Panel now for quite awhile in my garage with no problems. Been doing engine work, body work and alot of priming and painting. Well the other day I had to put some air in one of my tires, so I fired up the compressor in the corner of the shop(7 hp 60 gal) and filled the tire no problem. When I was done I was walking toward the compressor to shut it off and it kicked on to refill th tank. To my shock, there was a very big, pretty blue arc when the motor kicked on. I shut it off and restarted it several times and it arced each time. Now how many times has that motor kicked on while I've been doing primer and paint work in the same room. With the shop full of vapors. To many times to count. Yea I should have looked closer at it to see if the motor was intrinsically safe when I bought it but I didn't even think about it.(intrinsically safe is electric equipment safe for use in explosive vapor areas)
The compressor is being moved to another storage building behind my garage on my next day off. Just have to run a little pipe and wire thats all.
Folks be safe.
David
Old 07-18-2005, 03:26 PM
Mighty Mouse S-10's Avatar
Mighty Mouse S-10 Mighty Mouse S-10 is offline
Cleverly disguised as grownup
Thats why they are always in a little shed against the wall out back. Don't feel bad, just lucky.
Dave
Old 07-18-2005, 04:31 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Rob Keller's barnstar
Wiki editor
Last wiki edit: How to clean glass
Wiki Edits: 38
un less it is a explosion proof motor it will do it every time thats why the exhaust fan in a spray booth is explosion proof
it takes a high concentration of vapors to flash but its not that hard to blow your self up
just think what would happen if you had a gas line fail with the doors shut and the compressor kicked on
im glad your ok
do yourself another favor and build a complete cage with a roof around your compressor for security
sr66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 07-19-2005, 03:43 PM
nick62877 nick62877 is offline
also very bad for the compressor. you figure if the compressors intake is sucking in all that paint overspray and sanding dust , it's gotta shorten the life of the compressor?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Almost messed up big time"
Lineup problems big time FiefSS Hotrodding Basics 1 06-27-2004 10:31 PM
Big Time Ignition problem!!!!! 70chevy Engine 2 06-24-2004 04:41 PM
putting a big block in a 91 caprice greg johnson Engine 2 09-07-2003 06:43 PM
Just taking the time to say...Thanks. 4 Jaw Chuck Hotrodders' Lounge 50 09-04-2003 06:51 PM
First Time Posting and a few questions FriGuy Hotrodders' Lounge 5 09-10-2002 05:33 AM
