almost prefect
I am building a 50 Prefect, running sbc and turbo 400 into a nissan 280zx irs.
The original floors were plywood and the seats were bolted in with 5/16 bolts and large washers. Will plywood handle modern seat belt setups or should I use 18ga steel. I was also wondering if a pickup box floor would work. |
There are several things that you can do..build your own out of 18 gauge..or the pickup floor or you can even cut a floor out of a donor car that has the driveshaft tunnel and trans cover already premade..what ever works for you..it is all good just try and make a good job of it...The donor floor might even have seat belt attachment points and such that may work for you...
Sam
almost prefect
Thanks for the advice; I believe that 18 ga will be the way to go with 1" square tubing for support underneath.
| 48 Anglia Thames Gasser build | Bad Rat | Hotrodders' Lounge | 91 | 10-14-2010 03:39 PM |
| Intro | 52prefect | Introduce Yourself | 11 | 06-11-2008 01:17 PM |
| again, what is the prefect engine | BourgD | Introduce Yourself | 3 | 07-19-2007 07:39 PM |
| Ford Prefect | WoodieUK | Suspension - Brakes - Steering | 2 | 07-20-2005 11:46 AM |
