Almost from scratch - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2007, 08:53 PM
Almost from scratch
New guy building a SBC 350 to drop in a 33 Ford coupe project. All I have is a 4 bolt block with some aftermarket pistons, rods, crank. Also have a set of factory built Edelbrock Performer aluminum heads and a TH350 tranny.
Looking for suggestions to round this engine out as a reliable driver with some decent street punch for a light highboy. Maybe a little rumpity rump at idle, but not imperative. Want to stay with carb (s), no FI. Other than that, it can go just about any direction.
If you only wanted to build this ONCE and be done with it, what would you include?
Thanks for your input.
Old 10-31-2007, 07:28 AM
31 five window
Last journal entry: grill and rear end
I would drop in a 383 balanced rotating assembly for the most punch. If this is not in your budget at least put flat top pistons and an RV cam.this will be driveable and give great 0 to 60 on the street.
Designing my own scratch built Rat Rod, need guidance on where to start JerryMopar Hotrodding Basics 201 01-25-2015 06:48 PM
Clearcoat Scratch cgates Body - Exterior 2 05-02-2007 07:02 AM
build chassis from scratch viane General Rodding Tech 7 08-01-2006 06:12 AM
Welding Question?? Scratch Start?? 1931 steve Garage - Tools 3 01-05-2006 06:52 PM
scratch in paint black66 Body - Exterior 2 09-08-2003 07:21 PM
