The bolt heads for the band adjustment you need a 5/16 8 point socket which can be harder to locate.
for the input shaft end play its easiest to have the case sitting vertically supported so gravity isnt working against you.
The linkage bushings are readily available from mopar, dont have the pn handy but any worthwhile parts counter should know exactly what your looking for if you describe it to them. rockauto also has them, look under a 1992 Dodge truck, automatic transmission, shift linkage.
