Is this alright? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2009, 09:13 PM
V305's Avatar
On the Border
Is this alright?
Hey guys, found these pictures on the net, I think is a supercharger that comes with those 3800's from GM, is this posible and safe?
ID:	40855   Click image for larger version
Old 09-23-2009, 06:28 AM
woodz428's Avatar
Troll Hunter
Looks like one from a Supercharged T-bird. I haven't seen a Buick one for some time, but didn't think they had the rear intake like that one...they could. If you are wanting to use on of those on a rod engine, they should work well if size is kept in mind. Another important thing, although I'll have to look more closely at the pic you attached, is that most newer style oem blowers are only pumping air and not a fuel/air mixture and probably have tighter clearances. If you run injection or even LPG that enters under the blower it isn't something to be concerned about.
If you google "oem supercharger rebuilders/remanufacturers" or similar you can probably locate an online index and ID chart for the various ones.
Old 09-23-2009, 06:46 AM
How fast is fast enough?
I think the pictures would prove its possible- as for safety, well that's relative. Some would consider driving a car at all to be an unsafe practice.
Old 09-23-2009, 08:08 AM
Those are both Buick superchargers. The T-bird unit has an elbow at the back. Note that there are a number of different Eaton-style superchargers, ranging from the small units used on the 1.6 liter Toyota 4AGZE motors to the large units used on the 5.4 liter Ford motors. You want to match the blower to the displacement of the engine.
Old 09-23-2009, 08:23 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
wow that looks awesome. I might have to look into that. My gtp has a Gen 3 Eaton M90 blower on it. looks identical. with the throttle body in the back.
Old 09-24-2009, 03:40 PM
V305's Avatar
On the Border
So, it's not ok to put air/fuel mixture through one of these blowers?
Old 09-24-2009, 05:32 PM
BOBCRMAN@aol.com's Avatar
One of my customers is the engineer that developed the 3800 blower.
He told me that the seal life gets real short if fuel&air is run thru these. The seals are meant for air only
Alright cboy, where are the paint shots??? schnitz Body - Exterior 9 04-24-2009 06:17 PM
Alright JC here's quick tip. colormecrazy Body - Exterior 22 11-10-2006 06:42 PM
Alright I'm replacing my old th350 with a rebuilt one tonight, i have some questions! 61ChevyTruck Transmission - Rearend 17 09-12-2004 01:46 PM
Alright...I JUST don't get it?! Weimer Hotrodders' Lounge 295 02-18-2003 05:46 AM
Alright...I have had it!!!!!!!!!!!!! Weimer Hotrodders' Lounge 22 01-24-2003 01:30 PM
