Alsa mirror chrome question........... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2007, 08:02 PM
Last journal entry: 99 soft tail standard I painted
I have painted a freind of mines tank for his 1977 CB 750 Honda.I painted it with the Alsa black base coat,then cleared it with Alsa speed clear.All went well,and it looks killer.The directions say to wait 7 days before applying the mirror chrome,it also says not to scuff or sand the clear.My question is this........
He only wants mirror chrome on parts of the tank.Just on the sides ,in an oval.The mirror chrome will stick to unsanded or unscuffed clear,but will the top coat of clear im going to apply over the mirror chrome and cleared black stick to the unsanded clear?
Thanks in advance,
EVIL
Old 07-05-2007, 08:22 PM
heres a pic of the tank.........
Old 07-05-2007, 10:26 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
The "idea" is for the clear to be cured so's the "chrome" won't attack it and turn to Aluminum.Weather it takes 7 days or 3 depends on conditions.I wait 3 anyway just to be safe,longer if I have time.
ANY imperfection in the clear WILL show up in the chrome as a defect or effect if you want,so no scratching allowed unless you buff it back out slick.
Adhesion is a gamble at times with these chrome products but the idea is for the top coat of clear to hold it all together. You compromise it,and it could fail.
You could mask off the chrome ovals and scuff the black,reverse mask the black and shoot the chrome,clear,if that makes you feel better. Just more work and you can't mess the black up where ever the chrome goes.
You hammer the clear on too much and the chrome dulls from the solvent.
Mist coats of clear initally to cover it,likely it will dull,scuff with a gray pad and then hammer the clear and it will pop right up.Usually.
Old 07-07-2007, 11:50 AM
mrcleanr6's Avatar
get the tank all chromed, clear it, sand the clear, mask ans spray the black, clear again. basically you will be clearing 3 times. i have a bottle of mirra chrome here. its the first generation. i'm sure its been improved a little but every time i used it i had peeling issues. after i went to an alsa seminar i did notice the instructor sprayed it much more wet than i was. maybe that was the trick. i dont know. i personally dont like the stuff and its way too much work for the effect. as soon as you clear it, it dulls to an aluminum finish with no shine. again i haven't tried the newer versions.
Old 07-14-2007, 12:38 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Jim I use the moto chrome from innate... I think all of this type of paint is finicky.. If it the part is not wiped off perfect or if there is anything ( streaks, compound residue) left on it, the chrome wont stick.. I dont know what the long term will be with the chrome paints. but after doing a few sets of bumpers with it, I dont see how anyone can make much money at it.. I think im done with it.. Recently I have had to chrome everything twice to get the look.. meaning go thru the process, clear coat, then buff it outl, then re chrome it, intercoat it, then clear coat... Waaayyyy too much work for what you can charge..
BTW I have the latest generation of the moto chrome.. still super finicky
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 06:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 08:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 09:00 PM
nitrous 69BiRd Engine 2 11-28-2003 11:33 PM
