alt. conversion question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2005, 07:34 AM
frankenstang57's Avatar
waynenewtoneVil
Last journal entry: plans
Hey guys, I want to install a later model GM alt. in a freinds '65 Caddy. Anywhoo, I've installed one in my Mustang race car car, but went the route without the dash light, but a diode to the ignition switch. I was wondering if there would be a way to hook this one up so the amp light still worked in the Caddy. Any suggestions? Thanx!
Old 09-13-2005, 08:46 PM
docvette's Avatar
Wiki Edits: 12
monitoring
Doc here
Your easiest , best bet is to install an aftermarket volt meter to monitor the output it willl hook up to source and ground anywhere in the system..pefered at the battery....unless your going for original.
If that's the case you should revert to the 3 wire alternator, which should easily adapt to your stock charge light system.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
stupid alt. wiring question frankenstang57 Electrical 4 04-04-2005 07:44 PM
Cranecams Fireball XR-i points conversion kit question ken47 Electrical 6 10-21-2004 02:24 PM
ford generator to alt conversion 62galaxiguy Electrical 6 08-07-2004 08:53 AM
Alt Amp Question BM Ride 85 Electrical 6 12-22-2003 01:03 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
