Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Alt Light
Thread: Alt Light
Old 12-08-2012, 02:02 PM
timothale timothale is offline
Wiki Edits: 27
loose wire
I have a case backhoe that uses a bosch alternator. It quit charging so i put in new brushes, very easy on the bosch. then it was sometimes charging and sometimes not. The case only runs a low amp draw fuel flow solenoid, once it is running it will go all day on an almost dead batery. I took it in to have it tested and it did the same thing on the test machine. the mechanic said it had a poor connection inside the alternator, he wanted 300 for a rebuild, $450 for a new bosch. So I just put the charger on every 4 or 5 days Until get time to put on a GM one wire
