alt wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2011, 09:24 PM
alt wiring
Ive got a one wire alternator on my old car, Im building another car on the cheap and cant remember where the wires on a 3 wire chevy connect or which wire gets tied to the feed wire. Any help is appreciated
Old 05-09-2011, 09:44 PM
EOD Guy's Avatar
this ought to help it's for a conversion but it should provide what you need
Old 05-10-2011, 06:44 PM
If you scroll down to the bottom of this page, I think you will find this simple wiring diagram very useful.
http://www.expeditionlandrover.info/...ternators.html
Bruce
Old 05-11-2011, 12:32 AM
I just got done replacing the 10si that I'd installed in my courier p/u several years ago, using the "looping #2 to battery connector" method. this time, however, I connected #2 so that it only sees voltage when the ignition is on. Seems to be working fine for now, & hopefully no more power drain after sitting a week or two. anyone else tried this, or am I in new territory? I also did it this way because it seems like leaving the #2 terminal constantly on might shorten the life of the regulator/diode bridge?
please pardon my horning in on the conversation, btw.
EZ wiring - back up light wiring copdwg Electrical 3 06-07-2008 07:42 PM
wiring bird Electrical 9 08-19-2004 04:19 PM
GM Hei wiring jum Electrical 1 12-28-2003 12:29 AM
EZ wiring 38ChevyCoupe Electrical 12 08-18-2003 10:26 PM
wiring 67rscamaro Electrical 1 02-17-2003 04:44 AM
