alt wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2011, 07:13 PM
alt wiring
Thanks to all who replied to my previous question, But I didnt make myself clear. I need the diagram for an internal regulator alternator. Prior to my one wire that I have now, I had one with the no 2 wire tied to the main feed wire and I cant remember where the other field wire went. It worked fine like that. I wired the whole car from scratch and have driven it for years with no problems. Im very bucks down and need a cheap answer. Thanks for any help you can give.
Old 05-10-2011, 07:57 PM
Cape Cod Bob's Avatar
http://www.oldengine.org/unfaq/10si.htm
try this http://www.madelectrical.com/electri...hreewire.shtml
this may be better
Old 05-11-2011, 04:14 AM
EOD Guy's Avatar
Battery lug on the back of the alt goes to the pos post on the battery, however you choose to route it there, I ran mine to the radiator support junction terminal then to the pos post.
#1 wire is run to to an idiot light
#2 wire is spliced to the fuse box wire, to pwr everything else, and back to the feed from the radiator support jucntion as a sensing source to turn the alt on or put in in out put mode
wiring fordhotrod Electrical 0 10-02-2009 08:18 PM
EZ wiring - back up light wiring copdwg Electrical 3 06-07-2008 06:42 PM
s-10 v8 wiring tonydharley Electrical 0 03-14-2004 08:26 PM
EZ wiring 38ChevyCoupe Electrical 12 08-18-2003 09:26 PM
Wiring Stutch Electrical 12 06-23-2003 07:09 AM
