Altenator,battery or short?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2003, 04:52 AM
E.T. divided by $ spent= Speed
Ok,my daily is a 94 Dodge shadow.Yesterday it was raining hard and the alt. belt was squeeling.I go to a Grad party,leave,stop at a light down the road and the lights start dimming and the belt squeeling.I rev it and they get bright.I stop at a gas station to spray belt dressing on.And when I went to fire it up it was dead.Get a jump,everything is good,14V on guage,bright lights.No squeeling with dressing.
Get home shut it off and the dome light browns out.I'm parked in the wrong spot so I go to push it back I accidentally hit the brake pedal with my foot and bright lights and it starts again.??????
Drove it to a freinds and it started a couple times fine.
Go to start it today,browned out lights and won't start with out a jump.Once it goes down the road its fine.Stop at a frinds come out its dead again.But everytime you open a door you get a quick flash of bright dome light.Also when I jumped it it died as soon as I pulled the jumpers off,had to leave um on for a few minutes.
Old 06-23-2003, 08:30 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Sounds like a bad batt,or dirty cable ends.
Troy;
Old 06-23-2003, 03:25 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Tighten the belt up. It's probably slipping and the dressing only cured the sound but not the problem.
Kevin
Old 06-23-2003, 05:10 PM
bullheimer's Avatar
NEVER use credit cards!
ditto
clean the connections, replace the belt and get it on right, then remove pos connector and see if it stays running. this old trick still works doesnt it?
