altering stock HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2005, 03:16 PM
cool rockin daddy's Avatar
altering stock HEI
Hey fellas. I need to limit the amount of mechanical advance in my HEI distributor so I can run more intitial advance. Has anybody done this before? How did you do it? What is the rule of thumb as to how much less advance you get by shortening the slots a said distance? Is it worth it or do I bite the bullet and buy a MSD or comparable aftermarket distributor. Thanks in advance (no pun intended)!
Old 11-17-2005, 04:30 PM
347mustang's Avatar
hei's work pretty good for what they are and ease of wiring, and can be made to work good, but there is nothing better than a good msd dis. if you have the cash i recomend a pro billet msd unit
Old 11-17-2005, 08:17 PM
techinspector1's Avatar
Wiki Edits: 326
www.summitracing.com
Moroso advance kit part# MOR-72300 $8.95
Old 11-17-2005, 10:05 PM
Banned
yea, just use the advance curve tunig kit, yours from any autozone, orielys or advance for like 8 bucks, and they all stock them. I actually just recently had to go through mine and limit the mechanical as well as the vaccum (damn 10.5:1 iron headed engine that I "have" to get to run on 87 just to prove a point). A well placed washer is good for the vaccum side.
PS don't try to run a 10.5:1 engine on 87, its a real bich to tune. And if you do, pick a bigger cam than the one you have planned, trust me, its probably not big enough.
Old 11-17-2005, 11:01 PM
Wiki Edits: 326
What piston/head clearance did you use and what's the intake closing point of the cam you used?
Old 11-18-2005, 07:36 AM
Huh????
Did any of you who replied actually read my post. I don't want to alter how fast the advance comes in, I need to LIMIT the total mechanical advance of my HEI!!
Old 11-19-2005, 09:41 PM
coldknock's Avatar
Any shop with a distributor machine can do it. The slots get brazed to close them up a bit and then it's test, trim the brazing, test, trim the brazing...........so on and so forth until it's right. You can do it at home if you don't mind R&R'ing the distributor a dozen times to get it right.
Larry
Old 11-21-2005, 10:37 AM
thanks!
Thank you for your response. Now the trick is to find somebody with a distributor machine!
65 Chevy Firing Problems EazyDuzIt102 Engine 24 10-09-2005 09:12 PM
upgrade hei or go all msd Super Chevy Electrical 9 01-30-2004 12:59 PM
replacing stock HEI with Accel Jmark Engine 4 12-19-2003 03:31 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
Power to HEI Seon Electrical 3 09-27-2002 03:03 PM
