Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Alternate Turn Signal - - outside the box
Old 03-13-2013, 12:14 PM
gow589's Avatar
gow589 gow589 is offline
the Clever Turn Signal
Here is a short video of the Turn signal operation.
Note how the front is set up as a marker and turn signal. I have the left set up to flash back and forth between half bright and bright. The right is on/off. Not sure which one I will use.
Notice how the flasher still allows you to use your turn signal:
