alternative to Lizard Skin - Page 17 - Hot Rod Forum : Hotrodders Bulletin Board
  #241 (permalink)
Old 01-10-2012, 03:41 PM
327NUT's Avatar
Sorry was outside for a while.......yep I mixed my paint and micro balloons in a 2 gal. bucket. Wear a good respirator (very important) and pour about a third of the balloons in and mix VERY GENTLY with a paint stick, NO electric mixer cuzz the stuff will blow everywhere, it's like talcum powder. Keep pouring and mixing till you get the consistency you want or use the entire gal of micro balloons.
  #242 (permalink)
Old 01-10-2012, 04:48 PM
Any of you try the elastomeric paint's? I have read where the elastomeric component converts sound to heat and that it worked best.. I am also considering adding ceramic.. thoughts??? looking at the many pages, seems that the mixture outlined works well, but seems Spectrum or Lizard Skin has "other stuff" in it. Thoughts on that??
  #243 (permalink)
Old 01-10-2012, 05:02 PM
327NUT's Avatar
Don't know anything about the elastomeric paint, I really don't care for the idea of changing sound wave to heat...if thats what it does. The hot rods get hot enough as it is.....Dunno! The orig. "302 Z-28" formula worked out for a number of members who tried it and I sold the body before it was on the road. Give your concoction a try and see how you like it, can't hurt and it might be a better deal.
  #244 (permalink)
Old 01-12-2012, 11:32 AM
dinger's Avatar
Originally Posted by DanTwoLakes
In other words, you use a larger container and mix the two 1 gallon components together to make about 1 1/4 gallons?
That's probably very close.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
  #245 (permalink)
Old 01-12-2012, 12:55 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Read the Wiki article on ceramic insulation. There is a section on elastomerics like Kool Seal. CLICK HERE
  #246 (permalink)
Old 01-29-2012, 09:41 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
Originally Posted by 302 Z28
That would not be a problem, as I stated earlier in the thread we in the radio control hobby routinely mix the micro spheres with epoxy and polyester resin. The spheres are phenolic the only thing that can damage them is aggressive mixing which can crush them. They can be mixed with any kind of coating.
Vince
o.k. I may try this with an automotive paint, but if they can be crushed, doesn't that affect the use under your feet?
and if so. wouldn't them getting chushed. open up the paint to failure.. ?
nice thread, just can't see using house paint.. in a car..
  #247 (permalink)
Old 01-29-2012, 09:51 AM
stich626's Avatar
gearheadslife
Originally Posted by Heartbeat
After I finished all my metal work on the floor; replacing metal, welding etc (or so I thought); I coated all metal inside and out with an epoxy primer. Then applied the sphers and latex to the inside of the cab with brushes, rollers, using whatever I had. I use exterior latex paint as the binder. It works for years on my exterior house and trim it ought to work on the inside of my cab where I am expecting little or no water. I had some left over Ford blue impliment enamel which I painted over part of my work. It does seal the latex but I'm not sure it's necessary. Right now it's just an experiment.
No doubt other binders will work as well perhaps better. I started with the latex and stayed with it. I am pleased with the thickness of my application as I believe that provides effeciency. It withstands heat. I scorched it with my plasma cutter only right where I was cutting, even the epoxy primer disappeared with that treatment.
It's a hobby, have fun!
Heartbeat
I few things, exterior latex , has to breath.. or it will lift off the wood on a house.. think about that..
  #248 (permalink)
Old 01-31-2013, 04:12 PM
and if so. wouldn't them getting crushed. open up the paint to failure.. ?
This was a good question.. never got a reply.
Curious myself
  #249 (permalink)
Old 02-01-2013, 12:00 AM
327NUT's Avatar
M5.....I'll try to answer the question with my reasoning....for what that's worth. These micro baloons or sphere's are indeed micro, like I said in an earlier post this stuff is like talcom powder. You have to be extremely careful when you pour it and mix it or it will blow all over the place....hense the respirator.
It's not necessary to put it on the floor when you will lay down dynamat or equivalent and then carpet padding and carpet.......but it won't hurt it either. Once the mixture dries it's just as hard as any paint surface and you won't burst the bubble so to speak by stepping on it. Really no need to use automotive paint on the inside of the car, a good quality exterior latex house paint works very well.
Here's a few pics of my old glass body that I used this system on, my new body will get the same exact treatment.
  #250 (permalink)
Old 02-01-2013, 05:27 AM
Irelands child's Avatar
These micro balloons are about as fine as talcum powder - and a very good reason to wear at least a dust mask when you open the shipping plastic bag and pour into your paint. Probably somewhere in the first few pages of this thread you may see my car done with them as well - but I no longer can find the photos in my files. Now, do they work - heck, I don't know, but the floor of my car is well insulated otherwise and this was just some more, just in case
Dave W
  #251 (permalink)
Old 02-01-2013, 06:45 AM
Thanks to the both of you for the reply.
I am probably going to put it all over the interior of my truck. (including roof)
I also considered putting it under the cab.. (wondered if it might keep out heat from tranny, and exhaust)
These Atlanta summers get hot, and I plan on making some long trips. The cooler the better.
How many square feet did you guys say a gallon would cover... did you put on more than one coat. I had planned on rolling it on.
This is something I can do in between my other projects, so I think I'll see about getting some of this stuff ASAP.
My plan is to put this on, and then the fake dynamat over that. Should make a big difference
I am making a 46 Studebaker pickup and extended the cab 18".
THANKS again. I just joined so I can see where this forum will help me a lot.
  #252 (permalink)
Old 02-01-2013, 07:38 AM
If you buy a gallon of these spheres, then mix them into a gallon of latex house paint, you should be able to have more then enough to put a full two coats on. Get a Home Depot 5 gallon 'Homer Bucket' or similar to do your mixing and be prepared to spend a while folding the two together. I found that two and now pretty heavy coats took a long time to fully dry
And wear your dust mask!!!!
  #253 (permalink)
Old 02-01-2013, 08:08 AM
Wiki Edits: 22
If you're going to use Dynamat or some other sound deadener along with this stuff, put the Dynamat on first and then cover it with the mixture. Using Dynamat too might be a little overkill.
  #254 (permalink)
Old 02-01-2013, 09:18 AM
If I can do the both pretty cheap... that's cool.
I was hoping maybe the coating would help with the heat,.. and the dynamat for the sound. ?? I am new to this so I'm not sure how it all works.
I hear ya bout wearing the mast. I do some sandblasting so I have a respirator.
I "assume" once you get it poured into the paint an mixed, a respirator won't be necessary??
Where did you folks say you got the glassbeads.
As far as paint if just 'any' good exterior paint will work, I thought I'd check at Home Depot or Lowes and buy a gallon of "oops" paint that they mismatched for about $10
  #255 (permalink)
Old 02-01-2013, 09:28 AM
Once it's mixed, you wont need the mask.
An aircraft supply house like Aircraft Spruce will sell them - Search Results from Aircraft Spruce
You can also do a Google using Micro Spheres as you search phrase
I used Lowe's best exterior latex - not getting any cheaper either, but I recently bought a nice 'oops' gray at $2.50 for a quart which was perfect for what I needed for a home workshop project
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
anyone used Lizard Skin? henny496 Body - Exterior 25 11-12-2009 08:37 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 03:18 AM
Lizard Skin or similar products? bnewsom Interior 2 02-23-2006 08:43 PM
Lizard Skin........anyone used it yet ? Deuce Interior 5 01-13-2006 08:52 PM
Lizard Skin Cole Interior 1 01-05-2006 06:37 AM
