Probably going to put all others out of business!! I was thinking of begging Lizard Skin for a sponsorship because lightweight insulation is key for the Hudson build. Last edited by Rambo_The_Dog; 12-05-2006 at 10:08 PM. |
Is this the correct product
SC#1000 Super Hi-Build Thermal/Sound Supression Coating 1 Gallon: $59.95...5 Gallon: $299.75 As ths was in tne e-mail string Hy-Tech Thermal Solutions is a NASA spin off company located in Melbourne Fla. SC#1000 is available for about $39 a gallon. Also see this #1000 Insul-Flex Insulating, Waterproofing Elastomeric Wall Coating 1 Gallon: $32.99...5 Gallon: $164.95 I also have been into R/C for about 20 yrs. Regards, Steve Last edited by Bart; 12-06-2006 at 07:48 AM. |
Nice P51 by the way Vince |
We have been a dealer for Lizardskin for about two years and have had great results with the product and it does what it says. I would have to agree that after we put the $ exchange on the dollar and brokerage fees that it adds up. But when you look at this from a different approach its like this.The cost to have a shop install any other form of insulation cannot compare as you can cover about 50% more of the interior with this and you create a 100% waterproof barrier and a 20-30 degree reduction in heat at the thickness of your credit card.This is like buying 3 products for the price of one and with 0% waste,also what I like is that it does not add any thickness that affects the fit of interior panel's. When it comes to install time I would say that its half or less to other methods and twice the results. When we try to reinvent the wheel sometimes it cost more and we might not achieve the same results and we spend our hard earned money is it really worth it on the chance that we hit the formula right?And we really would not know if it was right until we had out interior in and a few hard road miles on the car so what would the cost be to remove the interior a second time to re-insulate?
Jason |
Jason
I do not think anyone was saying anything negative about Lizard Skin other than it's price. It is a great product, there is no doubt about that and it is considerably cheaper than other methods of insulation. However there is nothing mysterious or magical about it's composition. Ceramic insulation has been in the industrial arena for going on ten years now. There are numbers of insulation specific companies that offer comparable products at a considerable price savings. Being in the chemical industry with access to engineering data relating to protective coatings, it was not to difficult to do some research on ceramic insulation. Once I found out what it is I was amazed at the brilliantly simple formula and how inexpensive it is to duplicate. My suggestion was just that, a suggestion, a person can make up their own mind about what they wish to do. Thanks for the information Vince |
What do you think....
What would happen if the micro spheres were mixed in with an elastomeric coating such as Cool Seal? Cool seal is a mobile home coating that waterproofs and insulates. Obviously it will stand up to varying conditions.
Bob |
Vince |
. It is really a heavy bodied oil base material and not very nice to put on the roof of your camper. I think stirring in the micro spheres might destroy them.Dave |
Vince,
You gotta give this a try and report back to us! Bob |
Hey!
This is cooooool. Amazing the things you can find out if you look. Props to all for putting "2 and 2" together. Looks like someone's get rich quick scheme has been partially uncovered . . . I am needing to insulate my 68 camaro, and was previously going to use the thick jute padding with the foil backing on it. Would you guys say that I could do the latex / micro spheres thing and get as good or better results?? I don't know too much about Lizard Skin, just that it's expensive and reportedly amazing. I have an undercoating gun - normally you use a can of undercoating and the can just screws into the bottom of the gun - but I saved some empty cans "just in case." Would that work to spray that stuff? Undercoating is really thick and it would shoot that stuff like crazy. |
was just doing a little research.
Was looking at the wording in the Hy-Tech website: SC#1000 is a non-toxic water based sound and vibration absorbing coating blended with sound absorbing pigments and Hy-Tech Ceramic microspheres in a Viscoelastic resin. (Visco-elastic means that a material exhibits elastic and viscous properties allowing for better absorption of shocks.) Hmmm. viscoelastic - maybe we could add the micro spheres to regular rubberized undercoat? It seems to be "elastic" to some degree. They make it sound like it's not just latex paint that they use. In another area, for interior home sound control (a different product), they recommend a cheap latex paint to put over the special coating if you want a dark interior color in your home. They state that the resin in high quality paints destroys the sound control characteristics of that product. Maybe the same for the SC#1000? That almost makes it seem like there's a better filler material to hold the spheres. Perhaps that Kool Seal stuff is the best for this purpose. Where do you get that stuff?? Any thoughts out there??? |
As for the alternative's to Lizard Skin,out of all these idea's that are flying around here who has done any documented #'s that would prove that these other product's really work? I would also like to know if any of these have a fire rating or to they burn when they get over a certain temp?and I don't mean the spheres. The product's within the Lizard Skin are not the same as any off the shelf product and are different than the Cool Car product as we have spayed both and prefer the Lizard Skin Hands Down to any other product that is similar or jute.If it comes down to price on the RIDE Stick with the old W@llM@art Priced products that only work to a degree and use the proven products for results. Just my 2C adn opinion.
Jason |
This is extremely interesting, I,ll be doing my '32 Victoria body this spring and the thought of saving some bucks is very good. I,ve got a siphon fed sand blasting gun and big compressor, what pressure are you spraying this concoction with, and would it hurt to use a couple or more coats with drying time in between. Thanks 302, this is good stuff !!!
| Recent General Rodding Tech posts with photos |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| anyone used Lizard Skin? | henny496 | Body - Exterior | 25 | 11-12-2009 08:37 PM |
| Ford Alternative Restomod Article | datson280zxturbo | Hotrodding Basics | 1 | 05-31-2006 03:18 AM |
| Lizard Skin or similar products? | bnewsom | Interior | 2 | 02-23-2006 08:43 PM |
| Lizard Skin........anyone used it yet ? | Deuce | Interior | 5 | 01-13-2006 08:52 PM |
| Lizard Skin | Cole | Interior | 1 | 01-05-2006 06:37 AM |
