alternative to Lizard Skin - Page 22 - Hot Rod Forum : Hotrodders Bulletin Board
  #316 (permalink)
Old 09-15-2013, 08:27 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I'm sure nobody has, but give it a try. What do you have to lose? At worst it doesn't work, but if it quiets the car down even a little, it will be worth it.
  #317 (permalink)
Old 09-15-2013, 10:37 AM
test
do one test panel first using outdoor latex. or alkyd enamel better .at menards for 24 bucks a gallon. keep us posted on test
  #318 (permalink)
Old 09-15-2013, 12:42 PM
I'm thinking of using Latex just for ease of cleanup. I'm thinking this will make a mess.
  #319 (permalink)
Old 10-03-2013, 03:15 PM
Not that old of thread so I'm hoping people area still paying attention to it.
Was interested in finding out what the results were if you used some other paint instead of house latex. Our fab shop has a really nice primer they put on industrial duct work that I am planning on using inside my body.
I'm also a little confused why you would put the home made lizard skin over Dynamat? Don't they both do the same thing?
  #320 (permalink)
Old 10-03-2013, 05:50 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
The top ten reasons are: COST.
Those insulating glass microspheres mentioned can be added to any paint.
  #321 (permalink)
Old 10-12-2013, 08:51 PM
Following up on my post, I did my deck lid on my Chrysler today.
I mixed the micro-balloons I got from Wicks with a quart of Rustoleam latex paint. The mixture was thick, but still pourable. I removed the deck lid and striped out the lock etc. and taped all the openings except one access hole near the latch and the two holes where the hinges go in.
I poured the mixture in the three holes, and after sealing them with more tape, I then left it standing on each of its sides for a few minutes. As it dried, I left it in each position a little longer, spending most of its time laying face down.
When I was done, I removed the tape and propped it up on saw horses face up and let it drip for a while. To my surprise, not a lot of paint dripped out.
Got it cleaned up and put it back on the car later. First thing I noticed was the trunk closed with a much less "tinny" sound. When you knock on the sheet metal, it almost sounds like knocking on fibreglass, rather than the steel panel.
So.... I'd say it worked. If I were to do it again, I would mix up more than a quart of paint, but that's the only thing I would do different.
  #322 (permalink)
Old 10-13-2013, 07:51 AM
Is the Lizard Skin mixture for sound reduction or temperature reduction?
  #323 (permalink)
Old 10-13-2013, 07:54 AM
What about bed liner? Would it help with sound deadening?
  #324 (permalink)
Old 05-03-2014, 03:53 PM
Watching this thread...the lizard product is way overpriced so I always avoided it.
  #325 (permalink)
Old 05-04-2014, 05:55 PM
302 Z28's Avatar
Not a good alternative as it has very low heat dissipation and dries way too hard.
Vince
  #326 (permalink)
Old 07-10-2014, 11:11 AM
This thread brought me to your great forum here. I am very excited as this seems to be EXACTLY what I was looking for! Not only that, but I clicked on ONE other thread which was highlighted at the bottom of one page and it solved another problem that I've been wrestling with for a while. I'm a Jeep guy, not a hot rodder (someday!), but I've exhausted the off road forums for a few dilemmas I've got... I can't wait to see how many other problems I can solve searching around here!
Originally Posted by 496CHEVY3100 View Post
That is what I was thinking also .the bubble wrap will probably melt and I would keep a fire extinguisher close by as latex paint is flammable as is the bubble wrap.
the fumes from hot latex could be toxic also ,,,I would check before putting it under hood next to extreme heat. Just saying
This is one of my biggest concerns with many of these products. Not just that they're flammable, but many bedliners and asphalt-based products are VERY hard to put out once they start burning. I was relieved to see this post (which should be added to the wiki), but I will be doing my own test as well...
Originally Posted by Hi Rise View Post
...One of the nice things about it as it will not burn. I sprayed 3 layers on a test panel. Let it cure, scraped some off held a match to it. The flames just dies out immediately It will not support combustion.
Brian.
Many thanks to Vince and all those who contributed here!
Billy
  #327 (permalink)
Old 07-11-2014, 06:14 AM
hduff's Avatar
Billy
The first post is from 12-01-2006 and it's been active ever since.
I use a high solids latex paint, the cheapest of which turns out to be white ceiling paint, adding one quart of the ceramic microspheres to one gallon of paint. To spray it, I use a rented airless sprayer from Home Depot with the filters removed (there's one in the gun itself that people forget about) and a .025 tip. Of course, the spheres can be added to any paint and can also be brushed or rolled on.
I've also used process this to paint the interior walls and ceiling of my shop, my attic at home and the exterior of my business. It definitely is worth the effort.
  #328 (permalink)
Old 09-05-2014, 07:47 PM
PapaG's Avatar
Ask me, Cause I don't know
Last journal entry: Need things to do.
Some people were questioning the aluminum reflecting part being on the top of the p&s product. Here in the south where it gets very hot in the summer we have been using a radiant heat barring. It is a type "insulation" that reflects up to 95% from a heat source. Lots of brands, Big on home-green radio stations.
Radiant Barrier & Bubble Foil Insulation | Innovative Insulation Inc.
Lowes and HD should carry something like this.
My thoughts on this would be put this down first using what ever glue product seems to best way to you. Then use whatever you would be next, P&S, DM, KEEP cool, etc.It Should work any where. Used on Motor homes. Then go next with which of these products that you believe is the best product you think is best. Also how many of the those other insulating- nose blocking product you like.
Note I am not trying to change any ones mind on what they want to use.
DanTwoLakes makes some good points as some others others do.. I happen to agree that most of these companies make two products, one for sound and another one for heat. LS does and so does DM. I am not going back to check all the links on everything talked about. In reading through several threads on here and at least to on the HAMB. No one discussed the radiant barrier products. Rave reviews on home sites. Makes sense to me.
I do know some one who has used it is his house, big difference. He can even get in his Attic.You can walk up there in the dead zone in summer in South Texas.
I am going to do this in winter on my house.... My attic is a death zone now.
Just my two cents... HTH
  #329 (permalink)
Old 03-13-2017, 11:58 AM
Last journal entry: Fitting rocker panels
It's been a couple years, any updates to this?
  #330 (permalink)
Old 03-13-2017, 12:05 PM
hduff's Avatar
No updates. It really needs to be summarized and added to the wiki.
All I would like to know is if anybody used Lizard Skin and got the MSDS (Material Safety Data Sheet) and could post the contents information from it. That could settle several several questions.
Sometimes it's interesting what you can learn. For example, the expensive thinner sold by POR-15 is nothing more than mineral spirits which is cheap by the gallon at a local big-box, hardware or paint store.
anyone used Lizard Skin? henny496 Body - Exterior 25 11-12-2009 08:37 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 03:18 AM
Lizard Skin or similar products? bnewsom Interior 2 02-23-2006 08:43 PM
Lizard Skin........anyone used it yet ? Deuce Interior 5 01-13-2006 08:52 PM
Lizard Skin Cole Interior 1 01-05-2006 06:37 AM
