Very interesting, but I take issue with the latex paint. Would you want to paint the underside of your car with latex WITHOUT the beads? I shouldn't think so, I wouldn't. I think the beads should be looked at as an additive to enhance the thermal insulating properties of something you would put on your car anyway. Like undercoating or something that already has some useful acoustic damping and/or insulative properties.
KoolSeal sounds interesting and appears to have at least some useful properties. A lot of it's thermal usuefulness seems to come from reflecting heat from direct sunlight though. Not an especially useful characteristic for us unless we paint our roofs with it. More KoolSeal info. |
Just a follow up to some previous post. I was in Home Depot today and saw a new product by Kool Seal. It is caled Durolite and contains microsperes. Says it is 20% lighter. Sounds familiar.......
Bob |
just wrote a letter to kool seal to see what they think of there productss use for our purpose. I will post the letter when I get it. ED Last edited by Ed ke6bnl; 12-31-2006 at 10:04 AM. |
they also make a nice spray for interior wall sound deadening and one for thermal insulation that dropped the temp in my attic 12 degrees in the summer. Hoyt |
I thought that the brochure for the product already mixed (from Hytech) had said that they use a 80% by volume of the micro spheres. Above, with a 1:4 ratio it would be 20%. I guess I don't understand why the big difference. Am I missing something?? |
Vince |
The Directions for Use that were enclosed with the Hy-Tech microspheres state:
texastomeh |
i was confused also but in the posted mixing instructions it says "volume ratio" not "parts ratio". shouldn't it say 1:1 "volume ratio" not "parts ratio" ? honestly i have never heard of the term volume ratio only parts. can anyone enlighten me? thanks
He wrote 1QT of Additive for each gallon of paint.
That would give you 5 quarts of pain after you mix them together. It's that simple. |
When all else fails - read the instructions and remember that "parts" in some instances (not this one) can by WEIGHT. Also please note that as pointed out in one of my earlier posts - I fully intend to ignore the provided instructions and experiment with some various recipes of my own. Remember that there ain't nothing so good that it can't be improved (or screwed up) texastomeh |
Been an "on-looker" on this thread.
SO... has anyone completed any "experiments" with their micro-spheres yet?? Kinda curious as to how these homemade concoctions compare to the name brand, ready-made products. Thanks to the guys playing with this stuff so the rest of us don't have to Nooj |
efforts, observations, results
Efforts and some results
Effort: I purchased 2 one gallon bags of micro balloons fro Wicks Aircraft Supply at a cost of $13 with out shipping. Mixed one bag into a little over a quart of white Glidden semi gloss left over latex paint. This is dusty stuff so I wore a chemical mask and eye protection. I mixed the whole works by hand and got about 7/8ths gallon of material. Mixture was about as thick as thick pancake batter. I applied this mixture to the inside firewall and cowl of my 53 F-100 using a 2.5 inch nylon brush. I also applied the material the inside back wall of the cab below the rear window. I applied 3 coats to the firewall/cowl area and 2 coats to the rear cab wall. I tried to apply these coats as thick as possible allowing an hour between coats. My goal was to have the dried material as thick as a credit card. I estimate the total area covered to be about 30 sq ft and I used about 2/3s of my material. I then allowed 2 days for the material to set. Some results and observations: There was no gloss to the dried material and it will scratch with a sharp object. I don’t think I would use it on the outside of the cab. I don’t know if it felt like petting a lizard not having an occasion to do so; however it looked like flat wall paint and definitely had more texture. We had a warm sunny day here in South Texas before Christmas, around 80 degrees, and I rolled the cab into the sun with the outside of the firewall facing the sun. After a half hour or so the outside of the firewall became hot enough that it was not comfortable leaving my hand on the outside metal. The outside of the firewall is painted with two coats of epoxy primer. Inside the firewall I could place my hand anywhere without any discomfort. It was warm but definitely not hot. I do not have a point and shoot thermometer but my Craftsman 82400 multi meter has a temperature probe which I used on both sides of the firewall. I recorded a temperature of 124 F on the outside of the firewall and 102 F on the inside at the same place. The inside back wall of the cab was also in the sun and remained cool to the touch. It did not seem to absorb any more heat than the ambient temperature. Both sides of the rear cab wall felt about the same. I have now mixed my second batch. I bought a quart of exterior latex paint from Lowe’s mistake shelf for $1. The color was an off white a little on the beige side. This mixture came out as very dry peanut butter. Dryer than the kind you have to mix before eating. I was able to roll this mixture on the inside roof after the addition of about a pint of left over white ceiling paint. I had applied 2 coats of the remainder of the first mixture to the inside roof so that made the 3rd coat. I will add one more coat to the roof and then use the rest of the mixture on the floor. I still plan to use my Quiet Ride kit inside the cab but I believe the latex micro balloon coating to be a definite bonus. One further observation: the hollow, ringing sound when the cab wall was thumped is now changed to a dull thunk, definitely less vibration. All in all for the price and the effort, I am pleased. Heartbeat |
Great feedback Heartbeat! 20degree diff pretty good.
Only thing bouncing around in the back of my head is "What are the heat resistent properties of the latex paint? My concern would only be with exhaust routing too close to the application...or does the addition of the spheres change the behavior? Might be something to test. That's why - when I get time - I wanted to try some of this with an automotive grade paint that has heat resistance characteristics. If the spheres will hold up this would be a better overall implementation...anyone? |
| Recent General Rodding Tech posts with photos |
| Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
| anyone used Lizard Skin? | henny496 | Body - Exterior | 25 | 11-12-2009 08:37 PM |
| Ford Alternative Restomod Article | datson280zxturbo | Hotrodding Basics | 1 | 05-31-2006 03:18 AM |
| Lizard Skin or similar products? | bnewsom | Interior | 2 | 02-23-2006 08:43 PM |
| Lizard Skin........anyone used it yet ? | Deuce | Interior | 5 | 01-13-2006 08:52 PM |
| Lizard Skin | Cole | Interior | 1 | 01-05-2006 06:37 AM |
