Vince |
302,
Thanks, I went back and reread the thread again, and noticed you had mentioned as such. Did you also use the peel/seal after putting on the spheres??? Did you do both inside doors or ??? Thanks, just looking for best method.....to get both insulation and sound deadening... Crzi... |
Hi, this is a facinating thread. Lot's of good info. I too am an R/C addict...94 in Corsair G-62 (bentwings haha), 96 in P-51 5.8, 118in B-25, 114 in P-61 in process. I'm well familar with the micro-spheres you are using.
My project is a 41 Willys. fiberglass body so I don't have to worry about rust. From reading the thread, I can do the micro sphere and latex on the inside and then add peel and seal where possible??. Is that correct. It is nearly impossible to get to the skin side of the doors with the power windows installed. I think I could remove the doors and just make a mix that is a little runny and pour it in on the skin side. Then just roll the doors around to coat the inside of the outer skin. Does this sound reasonable.?? The complete door only weighs about 30 pounds so they are relatively easy to handle. I could even do 2 coats if necessary. The trunk lid has a liner already sealed to it so this process might have to be done to it the same way also. What do you think?? The rest of the interior is pretty accessable. It's a tiny car so I can do everything with a brush. I'm not sure what the upholstery is going to look like but there surely will not be much additional framing added. The doors will have a panel of ABS so I could easily use the peel and seal on the inside. I don't think latex will stick to the ABS. If it was well scuffed an epoxy primer or paint will stick reasonably well. I could mix micro-spheres with this too I would guess. Does this all sound reasonable??. I'd really like to do this before winter as there are a lot of changes going to be done and temps will vary widely. The really big question is that the entire car is fiberglass and scuffing the interior with Scotchbrite or something similar is nearly out of the question. The best I can do is to mist wash where I can with wax and grease remover or hot soap and water. Sometimes getting the wax off the glass can be a problem however the body was oven baked before I got it and it seems clean, I sure don't have trouble getting resinto stick to it.. |
You certainly could try all the things you suggested. I think I would remove the window mechanisms in order to insure that I got an even coat of material on them. I am willing to bet that the latex will stick just fine to the ABS as long as it was Scoth Brite'd first.
How in the world do you find time to build all those planes, fly them and also to work on a street rod? It lookslike I will not be able to get back into R/C until I retire. Vince |
Great thread guys. I almost ordered up some Lizard Skin the other day but was surprised at the price. I just ordered up 6 gallons of the micro balloons from Wicks (I have a couple of projects going).
I think I'll try using the Kool-seal - can you get it at Lowes or home depot? I will likely take the extra step of priming with Zinser as well, and to top it off I will also use the peel and seal in certain areas as well. As you can see below, I have a clean slate to start with inside my 38 dodge coupe:
302 thanks for the encouragement. Haha on the time for everything. Here is how you do it...you get layed off 6 months before you are ready to retire. You look for a job knowing that you will not get hired. Then you retire. You then have no money of course but you get a no brainer job that pays pretty good or you contract for a while and collect SS at the same time. It's strictly legal now to work as much as you like after retirement...infact it is encouraged.
Take time off to enjoy life. I was told to get a life...I got it now haha. I spent more time in the garage working on projects than I ever did working on a job. I get about 12 hours a day out there now...plus a couple sitting here on the computer. I'm going to order some of the stuff to do my interior shortly so I'll post a follow up.. thanks again That's a cool P-47 what motor?? |
I am planning on retiring April of 08, then I will have more time to devote to R/C. The ongoing construction of my 34 has consumed more of my time than I could have imagined. Vince |
My 6 gallons of micro balloons arrived from Wicks today
Maybe I'll spray some home-brewed lizard skin this wknd |
Here is some testing I picked up on today. It might be cool to try the alternate painy/microballoons then add one of the butyl mats noted here. What's the opinion?? It would look to me as a way to reduce the heat as well as sound resonance.
http://www.sounddeadenershowdown.com/ |
As far as the sound benefit, that depends on how many coats you are willing to apply and if you are using anything else on top. On my car I used a 3/8" double foil faced jute type insulation on top of the paint on insulation. The sound deadening benefits are awesome. Vince |
Is the foil/jute insulation something you got at Home Depot?? I'm on the way over there to see what they have. I think I may try the home brew stuff on my doors at least for now. They are fiber glass and very light weight. They remind me of getting in an ultra light airplane. Nothing to them. I think the glass and power lift weighs more than the door itself.
Maybe the jute based stuff will give some "weight" to the closing sound. The guy doing my uphosltery is holding me back for now untill he get done planning the rest of the interior. He is all for the sound deadening and heat insulation. |
| Recent General Rodding Tech posts with photos |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| anyone used Lizard Skin? | henny496 | Body - Exterior | 25 | 11-12-2009 08:37 PM |
| Ford Alternative Restomod Article | datson280zxturbo | Hotrodding Basics | 1 | 05-31-2006 03:18 AM |
| Lizard Skin or similar products? | bnewsom | Interior | 2 | 02-23-2006 08:43 PM |
| Lizard Skin........anyone used it yet ? | Deuce | Interior | 5 | 01-13-2006 08:52 PM |
| Lizard Skin | Cole | Interior | 1 | 01-05-2006 06:37 AM |
