Alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2009, 07:14 AM
zim@Eagle Mi.
Alternator
I bought a new altinator that was advertised as 100 amp. is there a method to test this?? My voltmeter still shows 14v as I believe it should, When it in underload(bag compressor) it shows zero charge. how do I check the output?
Old 05-07-2009, 07:40 AM
You need a ampmeter to check what the compressor is drawing.
Old 05-07-2009, 07:58 AM
zim@Eagle Mi.
And assuming that is ok (it doesnt blow 20 smp fuses) how do I check the output of the alt.?
Old 05-07-2009, 12:28 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The easiest way to check the output, is to just take your car to auto zone, checker, etc. & have them check it for free.
Rich
Old 05-07-2009, 01:55 PM
zim@Eagle Mi.
will do, Thanks
Old 05-07-2009, 05:54 PM
T-bucket23's Avatar
Wiki Edits: 26
If you take the alternator off it can be load tested on an alternator machine. It will be difficult to sustain a 100 amp load using the electrical accessories in the car.
Chet
Old 05-07-2009, 06:13 PM
Wiki Edits: 31
buy a carbon pile load meter from HF, should work ok... won't be a VAT-40 but it should be good enough to test what you want
Alternator not aligned, where'd I go wrong. Pics included bubbahotep Engine 3 09-17-2008 07:33 PM
How do I wire a 3 wire alternator when I used to have a 1 wire alternator??? billsbird Electrical 7 09-05-2007 10:01 AM
another frustrating alternator problem darom Electrical 13 04-09-2006 12:09 PM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 03:47 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
