Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Alternator
Thread: Alternator
Old 10-21-2012, 11:30 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by hotrodding vet View Post
I've done both I've kinda got it narrowed down to the belt is stretched or I need a bigger amp alt
If the belt is stretched, replace it...If your alternator is stock (70 amp or less) you need a bigger alternator. Check your out put at the battery, longer cables (maybe thinner cables than required) can effect the input to your battery.
If you externally charge the battery (with a plug in charger) and leave it for several days and it loses charge, you either have a bad battery or an electrical short in your vehicle.
Hope this helps
