alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2004, 09:29 AM
alternator
I have a almost stock 68 camaro and would like to put in a new alternator how big should i go before i need to worry about burning up the wiring? Thanks
Old 04-04-2004, 09:35 AM
dmorris1200's Avatar
doesn't play well with others
Alternators only output what your system requires. You can install a 200amp alternator and it will only output 47amps if that is all your system demands. Wiring is based on system demands more than alternator rated outputs.
BUILT FORD TOUGH
