Alternator bracket - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-27-2012, 03:40 PM
Originally Posted by KENMO
So this is how it would connect - hole 1 to bolt 1, hole 2 to bolt 2, hole 3 to water pump?
No, not quite.
Bolt 1 goes through hole 1 on the bracket, then through the alternator, then the upper hole (looks like #2 in your picture) on the manifold.
Hole 2 on the bracket is bolted to the lower hole on the manifold that you did not number.
The bolt that holds the water pump goes on the upper bolt just like the J-bar. This braket goes on first and the J-bar is on top of it, then the washer and bolt.
The included diagram from the '70 assembly manual should answer your questions. You'll have to be the judge on the motor mounts.
This will fit in a small box so I can ship to Canada and would add the difference to the price.
alternator bracket savagerusty Hotrodding Basics 5 09-27-2011 08:52 AM
Alternator Bracket zipfactor Engine 2 10-22-2009 11:59 AM
Help with alternator bracket 67cat Engine 2 03-11-2007 08:38 PM
Alternator bracket help! meschnebly Hotrodding Basics 11 07-17-2005 10:55 AM
