Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - alternator bracket for a camaro
Old 04-12-2011, 06:59 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by 67-4-fun
thats what a buddy of mine told me to do as well, just wasnt sure on a bracket and if the belt would be in the way of the lower water hose
If you use a crank pulley meant for use with a long water pump, you can mid mount it on either the passenger or drivers side. The long water pump crank pulley allows the entire alternator to fit in front of the block, unlike a short pump type flat crank pulley, so you can get the alternator in close to the waterpump just like a power steering pump would be.
The long pump crank pulley puts the belt out far enough that it doesn't interfere with the lower hose on a passenger side mid mount alternator.
The ones I've fabbed up have been variations of this mid mounting point. http://www.alangrovecomponents.com/i...235R_Fixed.jpg
