Im wanting to install a lower alternator bracket on my 1967 camaro to lower the alternator on the driver side only. will this work? has anybody tried this? I was going to an elec water pump so the only thing driving off a belt would be the alternator, so i wanted to lower it down to use a shorter belt..
The ones I've made are for about 2-3" lower mounting on the passenger side with a long water pump, just enough to get the belt to miss an electric waterpump but not so low as to interfere with the lower radiator hose. A more accurate description would be mine are "mid mount"
Some of the really low drivers side mounts, like the March billet aluminum Low Mount kits for street rods won't clear the front subframe crossmember of a Camaro or Nova, or the steering box of a Chevelle. If you are trying to do this with a short water pump style flat crank pulley, the alternator will be too low and too far out(because the size of the alternator to get it to clear the front of the block) to clear the front subframe.
Do you have one in mind that you have picked out?? Or still looking??
still looking, but what you described about the alternator hiting the sub frame is exactly what i was afraid of, I took a look to see by puting the alternator down low and thought that would be an issuse, but just waned to see if anybody else has tried this and made it work or not
Re-locate the alternator to the passenger side then mount it mid or low.JMO
The pic below is not the same engine that's in my 67 now but i did keep the alternator the same after i re-located it.
If you use a crank pulley meant for use with a long water pump, you can mid mount it on either the passenger or drivers side. The long water pump crank pulley allows the entire alternator to fit in front of the block, unlike a short pump type flat crank pulley, so you can get the alternator in close to the waterpump just like a power steering pump would be.
The long pump crank pulley puts the belt out far enough that it doesn't interfere with the lower hose on a passenger side mid mount alternator.
Works well with a mechanical pump and belt, but won't work with an electric pump, the belt from just the crank to the alternator won't clear the electric pump's motor(alternator is too high up) along with the electric pump doesn't have the mounting bolt bosses for that lower bracket.
very true, im thinking of just sticking with the mechanical pump and just run a long instead of a short.. like to run an elec pump but concerned with cooling running on the street since the flow never changes
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
