Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Alternator bracket help!
Old 07-14-2005, 08:14 PM
meschnebly's Avatar
meschnebly meschnebly is offline
I'm at wits ends here guys. I'm not having any luck aligning up my alternator. I'm locating it on the driverís side and my brackets donít seem to be working. I'm using the following brackets.
SUM-G4051 ALT BRACKET USE WITH G-4050
SUM-G4050 ALT BRACKET USE WITH G-4051
SUM-G4049 ALT ADJUSTER ARM
There just seems to be no way to line this adjuster arm up on the water pump. I have a Monza 305ci with a short water pump. Any help would be greatly appreciated. Maybe there is a different/better type of bracket to use?
Thanks
Mike
