Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Alternator bracket help!
Old 07-15-2005, 12:02 AM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
brackets
C3 Corvettes have the alternator on the drivers side with the short water pump. You may want to use these brackets.
Your problem might be the curved adjuster bracket. It is supposed to be bolted on with the upper drivers side water pump bolt. The bracket goes behind the alt with the bolt coming in from the rear.
