Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Alternator bracket help!
Old 07-16-2005, 10:01 PM
lakota lakota is offline
meschnebly, it looks like you're using a flat arm piece. Look around the junk yards for an older 60s Chevy V8. Some used an arm with a 1" S bend in it to alleviate the problem of different pully set ups. Don't go to great expense, use a handfull of washers for spacers. Use just enough to get your alt to the right alignment.
