alternator charging to much? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2005, 04:19 PM
New Member
i have a 69 camaro 383, the regulator is hooked up put in a new one and it still pegs out the volts gauge, the gauge goes to 16, so everytime you accel it pegs out, at idel its around 12-14???
Old 06-22-2005, 05:41 PM
docvette's Avatar
Wiki Edits: 12
Voltage
Doc here,
First get a volt ohm meter and with it running, measure the voltage across the battery with nothing on , Does it STILL read 16 Volts? or is it 14.4?
If it's 14.4 the gauge is shot, OR you may have a bad ground...
What alternator do you have and how is it hooked up? Internal or external regulated?
This should be your Schematic:
Verify that yours is hooked up this way, and if it is, and still charges high, you may have to adjust the Voltage Regulator..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-23-2005, 11:23 AM
New Member
thanks ill try this, any ideas on what else it could be?
