Alternator charging, then not charging - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2011, 06:40 PM
corvette77's Avatar
Giddy Up
Shortly after starting the car, the alternator gauge drops to less than 12 volts and the idiot light comes on, then a minute later it's back up to almost 14 volts?
I have a new battery and I have tested both the battery (running & not running) as well as the alternator output while running. The battery tests out perfect but the alternator only shows about 13.4-13.6 volts after the motor has been running for a few minutes. Connections are tight and everything seems to work fine but the fluctuating gauge is what I can't figure out.
Thanks for any help.
Old 07-20-2011, 06:45 PM
EOD Guy's Avatar
internal regulator?
Old 07-20-2011, 06:50 PM
LATECH's Avatar
Worn brushes in the alternator, or intermittent regulator, more likely the first.
Old 07-21-2011, 12:41 AM
coupe66's Avatar
I just bought myself a new regulator with brushes for my... eh, Volvo... And the way to see if the brushes are gone in that car is: all control-lamps in the instrument are on all the time!
/Pete
Old 07-21-2011, 02:41 AM
willowbilly3's Avatar
Last journal entry: Body mods
loose belt maybe?
Old 07-22-2011, 09:05 PM
corvette77's Avatar
Giddy Up
charging not charging
Belt tension is good, yes it is an internal regulator. I drove the car a bit farther distance this evening and the gauge fell to around 10volts and never came back. Just the last couple times I drove it, the gauge would fluctuate, tonight though, once it dropped down, it never came back up. I think you guys that mentioned the brushes may be correct. I'm going to take it in and have it tested and see what they tell me.
Thanks again
Old 07-23-2011, 06:12 AM
EOD Guy's Avatar
I vote for a bad, or going bad, voltage reg.
Old 07-23-2011, 07:29 AM
Wiki Edits: 27
Tractor does it
I have a bosch alternator on my Case 580, I installed new brushes,very easy, but sometimes the battery would be dead. The diesel only uses a fuel solenoid so it will run a long time on a good battery if the lights are off. Sometimes i would get a charge the sometimes nothing, I took the alt into a repair shop and sometimes it charged and sometimes it didn't during the 2 minute test. The tech said there was a loose connection inside . $ 300 for a new alt. I just carry jumper cables and can go several days with no problem. I have a GM one wire to install as soon as I get Time.
alternator not charging TMACPRO Electrical 1 04-22-2011 12:41 AM
Alternator over charging???? jigga99 Engine 6 06-21-2009 01:58 PM
Alternator Charging PAS55 Electrical 4 10-09-2006 11:53 PM
alternator not charging Seon Electrical 15 01-19-2006 06:03 AM
Alternator Not Charging bluechev4x4 Electrical 6 01-31-2003 04:53 PM
