Alternator Conversion For 72' Nova HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2002, 08:26 AM
Question Alternator Conversion For 72' Nova HELP!
I just baught this 72' Nova all origional and i am going to put a stereo system in it but the origional Alternator will not support the amp/subs. I was wondering if any one had done this or knows how? I NEED HELP! <img src="confused.gif" border="0">
Old 03-23-2002, 08:25 PM
Post
My first question is do you really need one? I've got some bass thumping subs in my old car with the stock alterator, and no problems. It's amazing how much a good new big battery will help.
Second question- how may watts RMS does your amp(s) put out???
Watts(RMS)/12 volts(actualy more like 14.7volts)= amps
500W RMS/14.7=34 amps
1000W RMS/14.7=68 amps
If I remember right the stock one should be about 70 amps? not too sure though. Unless you have your amps playing at max for extended periods of time you shouldn't need a new alternator. unless your putting in a very big system. In that case. make sure you know what you are doing so you don't make costly mistakes. There is alot to making a stereo system sound realy good.
to put a new one is, very simple. your alternator should be a 3 wire type. two should be together in a plug, the other is a single wire with a ring treminal that fits over a post on the back.
All you have to do is buy a new alternator rated at higher amps, that is a 3 wire(if your's is a 3 wire) and it just bolts in- pretty simple
a good place to look is
<a href="http://www.summitracing.com" target="_blank">www.summitracing.com</a>
This is a good time to replace old belts too!
[ March 23, 2002: Message edited by: BadBowTie ]
[ March 23, 2002: Message edited by: BadBowTie ]</p>
Old 03-24-2002, 06:02 AM
dmorris1200's Avatar
doesn't play well with others
Post
If all you're doing is upgrading to a higher output alternator just get one from the local auto parts store. They should offer a few diff. options (55A,70A,100A,etc.). The regulator only allows the alternator to output what the system needs at any given time. Also notice RMS Watts was mentioned. A lot of audio components are rated either peak, or peak to peak power ratings. These are not the same as RMS. I forget the calculation at the moment but RMS is much lower than peak or peak to peak ratings. RMS is what you need to know for your calculations.
[ March 24, 2002: Message edited by: dmorris1200 ]</p>
BUILT FORD TOUGH
Old 03-24-2002, 10:02 AM
New Member
Post
Yo clawdog... unless you're running a nuclear system the stocker should be adequate. I've run some pretty pumping systems, and never had a problem. If you're worried, pick up a simple replacement at parts store, 100 amp or better. I bought a kit to convert my old one to 130 amp through jc whitney like 20 years ago and it worked great, i don't know that i really needed it though. what system you installing? just for listening, annoying neighbors? or comp? I have since chilled out and only put enough sound in to be pleasant, deck and 2 or 4 with simple mono sub, cheap and easy, no x-overs, eq's or anything, getting lazy I guess. have a good one
