Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - alternator crooked
Old 11-21-2003, 11:03 PM
minesblown's Avatar
minesblown minesblown is offline
i don't know if this helps but when i put my motor back in i put on new belts. well for some reason it kept throwing the alternater belt not actually throwing it off, just turning it upside down and riding on the side of the pulley. i ended up putting the old belt back on, problem solved. if you or the store where you bought the alternater still has the old alternater you may want to compare the pulley location in reference to the case between the two. maybe they gave you the wrong one.
