Look at picture # 13 in my gallery. You can see the alt bracket bolted to the head although one mounting bolt is obscured by the fan blade. the adjustment arm is bolted to a mounting boss on the front of the eldebrock intake. This is a 1974 stock cast bracket and bolts in two places to the head. you can also see the shim I had to put under the bracket to space it out.
