alternator has a wire broken off. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2013, 09:36 PM
Just finished break-in of cam and the alt. was not charing while running it . One of the wires from the the 2 wire plug is broken and was taped off so I thought it was that way before as I cannot see where any other wire is broken . I haven't put the a/c comp. back on yet so those are disconnected yet . Where does the wires hook up from the 2 wire plug at the top rear of alt.? The other 2 heavier wires are hook-up but not charging yet???? Thanks
Old 07-13-2013, 09:59 PM
You need to provide more information on what you have. It sounds like you might have a GM alternator, but I'm just guessing.
Bruce
The Following User Says Thank You to 75gmck25 For This Useful Post:
f/bird (07-18-2013)
Old 07-14-2013, 09:36 AM
Srry ; I've been on the forums so much with other things , I have a 76 f/bird ,350 w/air the 2 wire plur in on top has a broken or spliced wire on one of the 2 . We can't see any place to connect it and it's not charging . It may have just been there and not noticed cause it had tapt on it but it was charging befor . Thanks
Old 07-14-2013, 10:37 AM
Those wires need to be connected for the alternator to charge properly. The No. 1 wire goes to the idiot light, the No. 2 goes to the junction block.
The Following User Says Thank You to joe_padavano For This Useful Post:
f/bird (07-18-2013)
Old 10-12-2013, 07:18 PM
Gauges
I'm assuming you mean the original sending units for the 53 6cyl engine. I just put new sending units for the 351 Cleveland in because the truck had the mechanical 3 cluster under the dash gauges and the original gauges are wired. I will give it a shot. I appreciate the help.
I had a ton of advice on how I was supposed to figure out the ohms output for each sending unit and how I needed to have a series of reducers and a whole bunch of other bull****!!
Thanks for the help!!!!
wire terminal broke off 2-wire alternator bullheimer Electrical 3 10-11-2009 11:22 AM
One-wire to 3-wire Alternator change nova69 Electrical 2 09-05-2005 08:18 PM
New Powermaster alternator, broken? arch Electrical 2 06-12-2004 11:38 PM
one wire / three wire, alternator hookup 65truck Electrical 1 10-24-2003 04:59 AM
2 Wire to 1 Wire Alternator bluesman123 Electrical 8 02-04-2003 01:06 AM
