alternator help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2008, 11:41 AM
alternator help
hey guys i have a '72 dodge with a 360 under the hood i recently removed all the wiring and instaled a complete msd ignition i did this because its a mud truck and i figured less wires less shorts but in doing so i removed my alternator fld wires and i dont know how to correctly wire them back i removed my ballast resistor and ignition modual please help i dont want to make brackets for a gm alternator thanx tyler
Old 02-21-2008, 04:25 PM
T-bucket23's Avatar
Wiki Edits: 26
I would try to locate a diagram, if I remember correctly those had 2 small posts for field wires. Not really sure but I thought the connector that goes on the alternator would only go one way
Old 02-22-2008, 06:31 AM
yeah there is two feild or fld post on the alternator in my diagram (chilton) the green wire goes to the regulator and the red goes to ignition modual but i did away with the ignition module so would i run them to the on off switch?
